I used Smartripper to rip down ALL of the VOB files from a DVD. So, now when I go to DVD2AVI, I preview the movie. Well, I know for a fact that there are deleted scenes on the DVD, but
why is it that I don't see them in the preview? SHouldn't it play the entire movie, and then the deleted scenes be at the end or something? I wanted to make a disk that had a Menu, using Nero, and have the deleted scenes included. Please help if you know how I can find them.
A second "for instance"... I have the DVD "Snatch" (great flick) and the second disc is extra stuff. It has a menu that lets you choose from "making of" and "deleted scenes". Well, I used Smartripper to rip this one down and it only shows me the "making of" movie in DVD2AVI. No deleted scenes again. Why is this? Didn't I use Smartripper correctly?
Confused...
Tandem
Ok, so now I feel like a bit of a dork, because I read a few posts down and someone asked that same sort of question. So now I understand it a bit more, but I still have a question. The DVD that I'm doing has LOTS of files listed under the "info>title>angle" box. vts_01 to vts_22. Under each of those, are multiple angles with files. How do I know what each of them are? Is there a way to preview them so I know what they are? Or better yet, is there a way to select ALL files from the DVD to rip so that Smartripper will automatically rip ALL of these for me? I thought I had ALL VOB's checked, but it only does the main movie when you have that checked.
Tandem -
yeah,
it should have a selector thing for 'movie', 'files' and such, click 'files' and then it should have a button for 'all' or 'none', click all, and then rip it.
you will have ripped the entire dvd once it has completed
Converting DVD Deleted Scenes to MP4 - Subtitles Don't Match
By rickydavao in forum DVD RippingReplies: 1Last Post: 14th Mar 2012, 01:46 -
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:29 -
Combined DVD Movie with Deleted Scenes?
By Ghtpua in forum EditingReplies: 3Last Post: 25th Aug 2009, 19:34 -
deleted....
By mjwhite in forum Latest Video NewsReplies: 1Last Post: 31st Dec 2007, 14:19 -
Remaking Special Edition: Inserting Deleted Scenes
By snipper_cr in forum EditingReplies: 0Last Post: 16th Dec 2007, 13:45
