I have already burned my vhs to dvd via sony vhs/dvd combo burner. I now have these dvd's and am having trouble getting them converted to a format to use with imovie. I have used mpg streamclip before but this time it doesn't seem to want to recognize the files in TS folder. I downloaded streamclip for mac and pc and both are running into same problem. I've been reading the forums but none of the answers suits my situation.
My pc is currently down so I am looking for a good converter for mac. There are a bunch of "dvd ripper suites" out there under various brand names, but they are $39-$49 and I don't see anything support forums for them. I'm not necessarily looking for a free utility, but if I'm going to pay for it I would like some advice from the experts.
Because my source is vhs tapes, the quality of the output isn't of high significance (although it could be in the future). The last time I converted to .mov files which worked fine with imovie. Should I be using another format?
I've not used a Mac or iMovie, but from reviewing the iMovie info page, the app is expecting video files or video imported from a movie camera. NOT vob files from a DVD. You will likely need to RIP the DVD's and convert/extract to mpeg2 files....then import into iMovie. And of course this will all get more complicated as you appear to be trying to use a Mac.
Good luckGoogle is your Friend
Audio clicks-converting VHS to DVD w/Canopus ADVC-55, firewire, iMovie
By Danae in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2010, 16:44 -
Dead Panasonic DMRES35V VHS/DVD Burner Combo
By Painasonic in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2010, 15:26 -
Exporting VHS burn from IMOVIE HELP!
By durdenwasright in forum MacReplies: 3Last Post: 23rd Oct 2009, 09:35 -
Tuner for Zenith XBR715 VHS/DVD(burner)
By solarblast in forum DVD & Blu-ray RecordersReplies: 3Last Post: 23rd Jun 2009, 12:03 -
VHS into Imovie (HD6) with Pyro AV Link Problem
By MacInMass in forum MacReplies: 3Last Post: 9th Apr 2009, 09:25
