Hi People,
i have a AMD Phenom II x4 955 and one AMD HD5770
and i wish to know what is the fastest software to do a ripp of DVD into H264 high Quality -> (~700MB - 900MB(output))
freeware or not, using CUDA ? and all my core ? and in a 64Bit version ?
thx a lot people![]()
Results 1 to 9 of 9
You can't use cuda, you have an ATI cardi have a AMD Phenom II x4 955 and one AMD HD5770
You might take a look at MediaCoder. They added CUDA a while back. I tried it when it first came out and found the results were poor. Maybe it's gotten better since then.
Baldrick X264 encore is slow like fairuse 2.8 ? because i was using this one, but it was slow (but powerful) i think he dont take care of multi core or GPU :/
ATI has a hardware h.264 encoder as part of Avivo. Last I saw it was pretty poor.
Nothing matches the quality of x264. And with a quad core CPU it's not much slower than the hardware encoders.
XviD4PSP, VirtualDub or other app for fastest H264 hardsubbing
By ryukent in forum SubtitleReplies: 2Last Post: 26th Jul 2011, 02:18 -
Best/Fastest Software for 700MB Movie
By EzK in forum DVD RippingReplies: 5Last Post: 21st Jul 2011, 07:02 -
Fastest way to convert H264 under OS X
By imanta in forum Video ConversionReplies: 1Last Post: 3rd Dec 2010, 13:01 -
Fastest / Best software for dvd to divx?
By butt_crack in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2009, 02:35 -
What do you think is the best and fastest software to backup Blu-ray discs?
By WPlotkin in forum Blu-ray RippingReplies: 9Last Post: 28th Oct 2009, 12:17
