  1. DVD Shrink gives a "wrong structure" when presented
    with a multi session disc, and to proceed I have to delete
    all but one of the tracks on the rewritable disc. Is there
    a (free) program similar to Shrink which doesn't have this problem?
    I use Shrink to tidy up beginnings and ends, miss out things like
    adverts in addition to shrinking to fit.
    Apr 2004
    Miskatonic U
    Has the disc been finalised (or is it a re-writeable) ?
    What if you copy the entire disc to your HDD first, so that sessions are no longer an issue ?
    Read my blog here.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just drag the VIDEO_TS folder from that disc to your computer hard drive....because that is all DVDShrink
    reads is a VIDEO_TS folder.....or a VIDEO_TS folder inside an .ISO image.
  4. I use rewritable + discs. I have used DVD Decrypter to rip the
    entire disc to the hard drive, but the problem is still there. (For some reason
    if I use the - RWs, I would have to finalise the disc to play it on the PC!)
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Recorders can produce some pretty funky structures, more so if multiple 'sessions' are used. Run the structure through FixVTS, then try Shrink again
    Read my blog here.
  6. Using FixVTS did the trick, so thank you very much.
