Why make a VCD if your DVD player will play MPEG Files? I would think it would be a great waste if time to make a VCD from a MPEG if your DVD player will play mpeg files?
Results 1 to 11 of 11
Originally Posted by mikestadnyk
You can store more video/CD if you burn in vcd or svcd mode, near 740 MB on a 74 min cd....and if you change player some day you may wanna play the vcd.
i'd love to be able to do both on one cd. y'know, have it as a vcd, and store the original file as well. i have a apex 1500 so it might work, if i can figure out a way to get a 432 meg file onto a cd with it's vcd counterpart
mikestadnyk: it is very easy with nero, just make a vcd as usual and then drag the mpg video to any folder or the root folder or make a new folder(not the tracks list window) and it will burnt as ordinay data and the other video as vcd on the same disc.
Originally Posted by t1955feb
everything in default setings. The DVD player is calling it a VCD then pulls up a menu with the list of files but is a just normal mpeg file. -
baldrick: u said i could burn both the original file and the movie as vcd format. but i can't do that cuz the original file is 432 meg. unless i misunderstood u, i don't think it's possible. the movie is 40 mins long, in case you wanted to know.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 02:51 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 04:24 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25
