Help,
My old card just shows pixels, I think it's gone. I'm looking for a new PCI express card for my 530 with or preferably without upgrading my 350w power supply. I play some games but mostly Blu-Ray movies. I'm connected to a Dell 2408 WFP with DVI connection. There are so many cards out there it's hard to choose the right one. I'd like to stay under $150 but can go higher for the right card. If I do have to upgrade power it's another $80 for 450w.
Thanks for your help,
chas638
Any of the last several generations of video cards need a lot of power. With that said, even cards several generations old can handle 1080P resolutions. Your biggest limitations will be size, power, and price. Depending on your case style, you may not be able to use a normal full height card.
Google is your Friend -
Get a ATI HD 4350 video card which will do fine with bluray. I just bought a XFX ATI HD 4350 Minimum Power Supply Requirement: 300 Watts.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150402
DVD Dell Inspiron writer drive .. blue screen
By holeepassion in forum DVD & Blu-ray WritersReplies: 14Last Post: 4th Sep 2011, 21:30 -
Dell Inspiron 1520. Black Screen
By jollyjohn in forum ComputerReplies: 6Last Post: 17th Jun 2011, 00:03 -
Upgrade video card for old Dell GX280
By neworldman in forum ComputerReplies: 1Last Post: 9th Mar 2011, 01:31 -
Dell Inspiron 1564 fan issues
By alintatoc in forum ComputerReplies: 3Last Post: 25th Apr 2010, 15:04 -
Adapter for Dell Inspiron 6000 drive
By bevills1 in forum ComputerReplies: 4Last Post: 31st Oct 2008, 13:31
