I HAVE SUCCESSFULLY BURNED A VCD, IT PLAYS ON MY COMPUTER USING POWER DVD, BUT WHEN I TRY TO PLAY IT ON MY (MINTEK 2580), DVD PLAYER IT WON'T PLAY! BURNED ON MEMOREX CD-R, USING ROXIO EASY CD CREATOR PLATINUM 5.0. ALSO PURCHASED SMARTDISK MVP TO MAKE VCD. DVD WILL PLAY THESE DISKS BUT I HATE THE SOFTWARE, IT LOCKS UP ALL THE TIME. HAVE ONLY BEEN ABLE TO BURN 1 VCD SUCCESSFULLY. PLEASE HELP?![]()
Originally Posted by WONG-K-YING
I USE ONLY MEMOREX OR SONY CD-R & CDRW. FOR SOME REASON WHEN VCD IS BURNED USING ROXIO 5.0, IT WILL ONLY PLAY ON MY COMPUTER. HAVE YOU HEARD OF ANY PROBLEMS WITH THIS SOFTWARE. HAVE ALREADY LOOKED FOR A FIX. THERE ISN'T ONE. CAN YOU HELP? :oops:
I am ruling out your DVD burner because you says it works on your PC. you can also change software. There tons of demo software out there. -
Nero works fine for me but in the beginning I also burned a few disks that didnt work, I also tried them on 4 different DVD players. All DVD players was supposed to play VCD´s but only one worked JVC-521... So it could be your DVD-Player that wont accept R or RW discs... I also have burned a few DVD´s (10-15mins) on a regular CD and they all work fine on my computer´s DVD but the regular DVD player wont accept....
Originally Posted by native90210
error and once he find out what it is you will be able to here OMFG that was it.
Why Won't it Play on my DVD Player?
By mreccentric in forum DVD & Blu-ray PlayersReplies: 17Last Post: 16th Jul 2013, 09:59 -
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 12:10 -
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 13:08 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 19:07 -
DVD player that will play Divx correctly.
By ThaDraGun in forum DVD & Blu-ray PlayersReplies: 6Last Post: 15th Oct 2007, 07:59
