Hello.
I wasn't sure where I should put my question, so I put it here. I wanted to know if you are able to encode a video that was taken with a HD camcorder then convert it to a DVD format so that it can be played on a regular DVD player? Or do I need player specifically designed for HD video playback or a HD TV?
The reason for my question is that my camcorder is starting to get crazy on me and I'm thinking of buying a HD camcorder. But I don't have a HD tv or HD dvd player, just a regular TV and a DVD player. Can this be done without having to buy all these new EXPENSIVE hardwares? Thank you.
You can convert the footage to standard DVD resolution using an app like ConvertxtoDVD. That's probably the easiest to use app for this purpose, plus it'll burn the DVD for you. Or if you want a free app which isn't quite as automated, AVStoDVD is very good.
But, you'll probably want to edit your footage before you send it off to be burned to DVD. In that case, you'll need to have a fast computer. If you have anything less than a Core2 Duo, fuggetaboutit.Last edited by Soopafresh; 11th Apr 2010 at 04:43.
"Quality is cool, but don't forget... Content is King!" -
Thank you for your reply. And as for a faster computer, yes, I did buy a new one with Intel's Core i3 530 with 4 gig ram after my other one gave up which I used for about 6 years. I think it's fast enough, right? Also, I have Procoder 3 to encode to other formats. Will this work to encode it so that it can be played on a regular DVD player?
How to burn the video camcorder files to a dvd
By MikeN in forum Newbie / General discussionsReplies: 6Last Post: 27th Dec 2011, 14:36 -
Need help with getting Hitachi DVD camcorder video on to PC
By scottb721 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 8th Mar 2011, 16:03 -
HD Video to DVD and buying decision HD camcorder
By ddinc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Dec 2009, 08:17 -
How to copy a video segment from my DVD-Camcorder
By dark_cyber in forum EditingReplies: 6Last Post: 15th Oct 2008, 03:20 -
Video (from camcorder) has no sound on DVD
By FLVidiot in forum Newbie / General discussionsReplies: 0Last Post: 16th Sep 2008, 18:23
