I can't figure out how to do this. I have two audio tracks that are designated right and left (each slightly panned to right or left) and I want to wind up with one stereo track. This should be really normal and easy. Perhaps too easy to actually find any questions or answers for it on YouTube or the web. Any help is appreciated.
Results 1 to 9 of 9
You could put 4 separate audio tracks into Vegas and if you were exporting to say MPEG2 stereo it would produce a stereo audio track. All you would have to do is pan the separate audio tracks to either Left or Right or in-between for a centre fill. It's all there in the help file btw.....
After you have exported your work to a new file if you were to load this into Vegas you would see immediately a video track and a stereo pair on the time lineSONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
OK, so if I set the levels for each track, the two tracks combine will wind up being at that same level, then? So what I was trying to do isn't necessary, I guess. I'm concerned about having consistency of audio levels in my YouTube vids since some of them were varying quite a bit from others, I'd noticed. I thought that by having two separate tracks, I wouldn't be able to get an accurate level in Soundforge
Monitor the preview playback with the peak meters and your ears while setting levels and pans for each track.
http://www.kiva.org/about -
Using Vegas you can also insert a compressor limiter in the output chain to restrict the dynamic range and make your track sound louder on Youtube. There are a number of built in audio fx and compressors and reverb etc. as well as video fx.
sony vegas not rendering all tracks
By nukegumbo in forum EditingReplies: 5Last Post: 30th Apr 2014, 15:22 -
Problem with importing audio from movie track - Sony Vegas Pro
By tooninoz in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2010, 00:39 -
No audio track when importing mpeg2 into sony vegas? How do I fix this?
By bojadada in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2009, 10:53 -
Stereo mixing in Sony Vegas 8 Pro
By jnaizer in forum EditingReplies: 2Last Post: 1st Jan 2009, 03:14 -
Sony Vegas 8.0b - Bug with Audio Tracks
By Cunhambebe in forum Newbie / General discussionsReplies: 0Last Post: 21st Jan 2008, 13:17
