How to change IDX/SUB framerate with Windows 7 64Bit ?
I know that Vobsub Cutter can do it and I've done it hundred times before but with 32Bit versions of Windows
Vobsub Cutter doesn't work with 64Bit![]()
Results 1 to 9 of 9
Thank you very much
I used SubtitleCreator 2.3RC1 (because older versions gave me error in opening IDX/SUB files !) and it can do all I want but there is a big problem with this program :
Alot of IDX/SUB subtitles would have messed up colors when I change the framerate and save them !
And sometimes alot of lines is painted black in a strange way !
Here is what happens :
First when I open the IDX/SUB file :
Then when I change fps and save the file and reopen it :
The colors can easily be changed. I use VobSub Configure for that (comes included in the VobSub package). I don't guess you see that purplish stuff when actually using the subs, but if there's anything else wrong after the framerate conversion, I wouldn't know what it is as I've never had any problems converting the framerate using SubtitleCreator. Perhaps there's something wrong with the subs to begin with. Sometimes opening and then saving them immediately can fix that. After that then you might try to change the framerate. Might work, and might not.
I don't know then. And I was going to upgrade to 64 bit W7. Maybe now I'll stick with the 32 bit version. I do too much subtitle work to have problems like that. I apologize for not being much help
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
Glad it worked for you.
Change MP4 framerate
By exon in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 09:00 -
How to change this script to burn idx/sub subtitles?
By MousE0910 in forum SubtitleReplies: 4Last Post: 21st Feb 2010, 14:04 -
HELP - MKV reference framerate change problem
By danielo in forum Video ConversionReplies: 5Last Post: 20th Aug 2009, 07:22 -
How to change framerate in XviD4PSP other than 15.000 ???
By d003232 in forum Video ConversionReplies: 0Last Post: 26th Apr 2009, 14:24 -
Change framerate of H.264 video without re-encoding?
By Mizkreant in forum EditingReplies: 5Last Post: 4th Jul 2007, 22:44
