    Apr 2010
    Perth, Western Australia
    Hello, I've been trying ot find our how to get our Samsung DVD SH855 Region Free to be able to play all regions. I found one link that explained it for a Samsung DVD SH855M but am not sure if I can use it for our one too. Thank you so much for any help someone can give us. Kind Regards, Mishyinnes
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Nobody here makes or creates DVD hacks. If it is not in the list to the left ( DVD Hacks)....you are most likely on your own or out of luck.
    Apr 2010
    Thank you for the quick reply, I'm not the most technologically minded person so was wondering what you meant? These codes are out there as thankfull it's worked for others. I gather that it's all at one's own risk, but do you mean that you're not sure if the same unlocking system would work or ???. Thank you again.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Not all players can be hacked. Many players can never be hacked. Some players have never been hacked and never will be hacked.
    Got it?
    Apr 2010
    Hi, I have a code that can be used on our machine but I can't get into the section that allows me to input the code. It says to press repeat but the button takes us into the main menu and from there we don't know where to go, please if anyone can help that would be very appreciated. It is a code that exsits it's not that its been 'made' or 'created' so it's known. Thank you, Kind Regards, Mishyinnes
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then just post it here for now.
    Make the DVD region free, not the player.
    More info on making region-free DVDs to play international discs on your region-locked player.
    Jan 2007
    Republic of Texas
    Yes, listen to lordsmurf. Manufacturers often make updates to their DVD models, and there is always the risk of rendering your player inoperable by attempting to hack it. Instead, make region-free backups of foreign DVDs on a DVD-R.
