    Apr 2010
    Bundaberg, QLD
    Has anyone tried to capture a stream on the NBC website? I've been having problems ripping this using StreamTransport (link). It says buffering and stays like that for two hours, so I think it's a problem with the player or my settings.
    If anyone could somehow capture the link to the video I'd much appreciate it, because I'm dumbfounded.
    In streamtransport try press stop/pause and resume a few times and it might start.
    Apr 2010
    Bundaberg, QLD
    Hmm, turns out it's not a problem with StreamTransport, as Internet Explorer, Chrome and Firefox all yield the same results I think I've given up on this NBC Player working, it seems like terribly designed software.
  4. Try RTMPDump:
    rtmpdump.exe -r rtmp://cp37307.edgefcs.net/ondemand/nbcu/nbcrewind2/c278489e039c04f40089cc5e76738187_0700 -W http://video.nbcuni.com/embed/player_3-x/embedded.swf -o filename.flv
    Nov 2005
    i had the same issue and the only way to capture NBC streams is with a capture app like Snag IT. Works ok
