I just copied a few home movies from vhs to DVD using Sony vhs/dvd burner. I have fully functional dvd's now that play on dvd players, pc's and mac's. I want to edit them in imovie so I would like to create a .mov from my dvd's. I've done this before a while back and had no problems. When I try and use streamclip though it keeps telling me it can't because of "unsupported file type"
The one problem could be that my dvd burner makes a main menu by default, so the dvd doesn't just play the movie, you actually have to click the title. When I select "open dvd" it says "unsupported file type". When I select open files I select the video_ts.vob file and it just shows the menu screen of the dvd. Could I be missing a codec or am I skipping a step?
Thanks in advance,
shard
streamclip: 1.9.3b2
mac: os x 10.5.8
Baldrick, thank you for the reply. I don't have a VTS_01_0.VOB file that I can see. In the Video_TS folder I have:
VIDEO_TS.BUP (GREYED OUT)
VIDEO_TS.IFO (GREYED OUT)
VIDEO_TS.VOB (SELECTABLE)
VTS_01_0.BUP (GREYED OUT)
VTS_01.0.IFO (GREYED OUT)
VTS_01_1.VOB (SELECTABLE)
VTS_01_2.VOB (SELECTABLE)
VTS_01_3.VOB (SELECTABLE)
VTS_01_4.VOB (SELECTABLE)
VTS_01_5.VOB (SELECTABLE)
Thanks in advance,
shard
convert .mov or vob file to .flv
By Giacomo in forum Video ConversionReplies: 5Last Post: 3rd Feb 2011, 13:03 -
Looking for a Mac app to convert .vob to .mov...
By Abiyad in forum MacReplies: 2Last Post: 22nd May 2008, 17:04 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 12:30 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 10:51
