I'm "borrowing" a machine at work to help with my video conversion project. The machine is a dual quad-core Xeon E5520 2.7GHz with 12GB of RAM. I'm going to be converting mostly xvid/divx files to h.264. I installed Windows 7 x64 thinking that would give me my best choice of programs to use but in searching around, it looks like there aren't many options that will take advantage of the 16 logical processors on Windows (due to lack of 64-bit support). So my questions is:
What program would you recommend with this setup? I'd like for it to take advantage of _all_ the processing power if possible. I don't mind throwing Linux on there if that's what it takes.
Thanks!
Results 1 to 1 of 1
Software Advice Wanted
By CthulhuSaves in forum DVD RippingReplies: 3Last Post: 16th Feb 2011, 13:25 -
Software advice please
By mauiwowi in forum Capturing and VCRReplies: 1Last Post: 15th May 2009, 10:54 -
Software advice needed
By ccm in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 12:01 -
editing software advice
By tommcd64 in forum EditingReplies: 4Last Post: 27th Oct 2007, 19:44 -
Software Advice
By asdfasdf in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2007, 11:27
