I've been downloading some DVD torrents and here are the steps I have been doing to create to a DVD.
I use VUSE to find the files I need.
I use DVDFlick to convert the AVI file to DVD format.
I then use NERO 6 to burn the DVD. My issue is when Nero wants to burn the disc it ejects my DVD +R discs ( including DL discs) and request I use a "DVD" format DVD. I've been changing parameters in DVD Flick hoping that it will create a file that will allow Nero to burn as a R+ but no luck so far. I'm sure I'm missing something very obvious so thanks in advance for any help.
Results 1 to 15 of 15
Can you burn data to a dvd? The problem is sounding like the drive itself is the issue. At this point I'd run an optical lense cleaner through it and see if it resolves it.
Yes it burns fine. The problem is the encoding thye software places on the file when it's converted from AVI to DVD format. I'm sure somewhere there is a setting that says create the DVD file as a DVD-5 or DVD-9(DL I think). I'll keep looking for software that does this. Nero even though the setting is DVD-5 will ask for a disc that is DVD format. Don't know why - I figured it has to do how the file is originally created.
Thanks for your help. -
Extra points for the "Tyranny & Mutation" avatar there, pal!
Stiiv -
I, too, like that BOC avatar. Great LP. Am still especially fond of Wings Wetted Down after all these years.
Video Capture Issue - MPEG format
By SD123 in forum Capturing and VCRReplies: 18Last Post: 11th Feb 2011, 14:48 -
Sony Bravia 40" BX400 - USB Video Format issue
By dreamcast in forum Video ConversionReplies: 4Last Post: 16th Oct 2010, 08:49 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
SCANDISK SD memory Card Format Issue
By Johnnylee_hang in forum Off topicReplies: 5Last Post: 3rd Feb 2009, 17:33 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21
