Hey everyone, new user here with a simple question:
I don't want to ask a question that has been answered already a thousand times, but I've searched for this topic and, unless I have missed it, the existing posts don't quite cover what I'm looking for.
I think it's a common newbie question, so here goes:
I have converted an old VHS tape to DVD using a DVD recorder. The file on the DVD is now in VOB format.
What I want to do is take the VOB file and convert it into a different format, preferably MPG. I then want to edit the MPG accordingly. What conversion programme is best to use for this?
I have tried it before, using free software that I have since forgotten the name of, each time unsuccessfully, the file either corrupted and had no sound/picture, etc. There seem to be so many different packages available but some of them are very involved and I don't want to do anything terribly technical, just a simple conversion that many people seem to have mastered.
Can anyone suggest something basic, to convert and then edit with?
Thanks in advance.
Results 1 to 12 of 12
This has been asked 8 million times. See https://forum.videohelp.com/threads/169081-How-to-convert-DVDs-back-to-MPG-files-for-re...thor-or-reedit
If you want free tools use vob2mpg and then edit with mpg2cut2.
If you want the best tool, use videoredo. It can also import dvd vobs directly. -
Thanks for the responses. I knew it had been asked many times before but as I mentioned the other topics that I found were covering a more indepth request than the relatively minor task that I want to perform is.
I previously tried VOB2MPG before but the results were not very satisfactory at the time. -
OK everyone, I'm back to this subject from a couple of weeks ago.
I have another similar, related question to this topic.
I've tried the VOB2MPG software, and the results are very, very poor, resulting in a pixelated, blocky MPG file.
Are there better results in converting VOB files to AVI files?
I've since realised that I can edit AVI files in Adobe After Effects, which, whilst horribly complex, is a better editing tool than, say, MPG2Cut2.
So, opinions? Is it best to stick with VOB2MPG or try a VOB to AVI programme?
Thanks. -
As far as converting VOB to Mpeg....... you are strictly changing from one container to another...... correct?
There is no re-encoding of the actual content or anything of that nature....... correct?
TCMy Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650 -
The VOB is fine, it has perfect image playback both on regular DVD player and on my PC.
I played the MPG back on the regular Windows player, and the results are definitely blocky, in the same way as failing digital TV picture.
And I am simply running the VOB file through VOB2MPG, and nothing else. -
Have you tried playing it using a player other than Windows Media Player, like MPCHC, or VLC?
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
VOB to MPG
By marbletravis in forum DVD RippingReplies: 2Last Post: 24th Apr 2008, 12:40 -
VOB to MPG from a file
By GaryNas in forum Video ConversionReplies: 3Last Post: 19th Aug 2007, 20:50 -
Problem with .VOB to .MPG
By SilverFalcon in forum Video ConversionReplies: 2Last Post: 30th Jul 2007, 14:27 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
