Hi,
I need some help here. I have a video stabilizer – I think it’s called SIMA and it works perfectly with my old recorder. I recently bought a new recorder – Magnavox ZV420MW8 , but always get a “copy protected” message when trying to record VHS or DVD to a DVD using a new recorder.
The source players are the same, so it has to be something to do with a Magnavox…
Please advice and thanks for your help.
Hello Alon_o,
There is probably nothing wrong with your new recorder. It’s just a newer version of Macrovision protection that is built within it and your SIMA is probably too old to handle that. As far as I know the company that produced SIMA is no longer exists, so try something else – I personally use DIMAX GREX , btw I had the same problem when changed my recorder, but they exchanged my GREX unit to a new one just for free!!! -
Well, thank you so much! I'm sure this GREX is a great unit, but I did'n have any money to spend this month , so I'll keep using my old recorder for now..
Which is better, Phillips or Magnavox BD-R?
By jbitakis in forum Blu-ray RippingReplies: 2Last Post: 18th Nov 2011, 15:35 -
Magnavox ZV420MW8 VCR/DVD Recorder ??????????????
By JABIII in forum MediaReplies: 0Last Post: 3rd Aug 2011, 06:31 -
What brand / pn works best with Magnavox ZV420MW8?
By Legendsk in forum MediaReplies: 0Last Post: 26th Sep 2010, 21:28 -
My Magnavox problem
By LadyLiete in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Jun 2010, 07:03 -
magnavox nb500mg1f
By jswatkins in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Dec 2009, 01:20
