converted a Pal letterboxed 4:3 avi download to Ntsc 16:9 dvd. I think the original source was letterboxed, probably widescreen (the movie was released as 1.66:1). When I play the result with TV in widescreen mode, it's too stretched out (too fat, not too tall).
Tried adding side borders, but overall picture gets smaller. Then tried cropping off the letterboxing (60 pixels top and bottom), it looks fine in widescreen. Should I do that or what?
Attached a sample from original avi.
sample.avi
Results 1 to 9 of 9
Yea if you are converting to 16/9 WS NTSC you have to add borders to the side to get the correct ar of 1.66:1. That's the only way to fit the ar into a 1.78:1.
I don't know if you use avisynth but the code after cropping away the black would be around:
Code:lanczos4resize(672,480) addborders(24,0,24,0)
did a sample, looks good on the TV, thank you mucho. I'm curious how you figured that out.
Here's the script I'll use:
AVISource(etc)
Crop(0,60,0,-60)
assumefps(23.976,true) -
720 * 1.666 / 1.777 ~= 675
Then he rounded to the nearest mod8 size (better compression, fewer artifacts). -
Should I have not cropped so much?
Or given the amount I cropped, would that change the size of added borders?
When I say it looks good, that doesn't mean it is good. I thought it looked good with just cropping, but adding borders was a definite improvement over that (when I could compare them on TV). -
I don't have the video here anymore but I seem to recall 60 lines off the top and bottom was about right. Within a pixel or two.
Thanks, that's a relief. I didn't want to encode it a 3rd time.
I had the impression that the original dvd was letterboxed widescreen (I saw a still image with subtitles overlapping the image and bottom border), so I wasn't sure why it wasn't fitting with the letterboxing.
Aspect ratio problem: Converting 2.35:1 AVI to DVD w/out squishing
By Calidore in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2015, 11:33 -
aspect ratio problem when converting
By ibzomie in forum Video ConversionReplies: 2Last Post: 19th Nov 2011, 15:43 -
DVD with 16:9 aspect ratio truncated on Vizio widescreen TV
By gschmidt in forum Authoring (DVD)Replies: 14Last Post: 29th Oct 2011, 17:48 -
Aspect ratio problem when converting from VOB to AVI
By digga123 in forum Video ConversionReplies: 5Last Post: 29th Dec 2009, 04:28 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 17:01
