This may be a stupid question. When I download and install DVDFab 7 HD Decrypter, when I open the program the the title says "DVDFab". I have noticed that the image posted elsewhere in this forum, the title says DVDFab HD Decrypter. What am I doing wrong? How do you open just the decrypter? Why is my title say DVDFab and not DVDFab HD Decrypter? Thanks for any help.
DVDFab HD Decrypter is just the simple free decrypting version..DVDFab is the full-featured version..
" Who needs Google, my wife knows everything" -
Maybe I didn't phrase my question correctly. I am only interested in DVDFab HD Decrypter. When I download the newest beta version for it, when I run it the title at the top says DVDFab and not DVDFab HD Decrypter. Other postings in this forum show a screen shot of the decrypter which are titled DVDFab HD Decrypter at the top. Basically, I want to make sure I am using the free decrypter and not the DVDFab options. Thanks
When you boot up the DVDFab it should show a box with all the software available to you. The bottom one should state DVDFab HD Decrypter-------Never Expire(if you didn't purchase this then the others will say Not available) . The Program will decrypt the files your attempting to do once you select the disc or folder. It will place it in the folder or disc you select. If this is to much, just uninstall the current version and go to this link and obtain your tools that should show you DVDFab HD Decrypter to make you feel comfortable.
https://www.videohelp.com/tools/DVDFab_Decrypter
If the Light ain't Bright, It ain't Right!!
DVDFab Decrypter
By HacktheHacker in forum DVD RippingReplies: 11Last Post: 25th Feb 2008, 23:10 -
DVDFab HD Decrypter and BD iso
By rhegedus in forum DVD RippingReplies: 5Last Post: 13th Oct 2007, 05:13 -
DVDFab HD Decrypter Issue
By adcmarti in forum DVD RippingReplies: 11Last Post: 27th Sep 2007, 23:24 -
DVDFab HD Decrypter???
By bltprf in forum Newbie / General discussionsReplies: 11Last Post: 9th Jul 2007, 00:09 -
problem with DVDFab Decrypter
By cmonzon in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 20:18
