  1. How to connect a dellE228WFP 22" LCD monitor to a time warner cable box?
    NEW:::::GOT THE CABLE BOX AND IT DOESNT SEEM LIKE I CAN DO ANYTHING WITH IT I REALLY STILL NEED HELP OLD:::::::A friend recently gave me an dell monitor which has dvi-d and d-sub(hd15) connections i want to use it as a tv....i've been to a pc store 3 times now looking for the right cords...1st they sold me a vga to vga witch was useless i only could watch dvds on my laptop on the monitor...2nd time they sold me an vga to rca(red,yellow,white) adaptor (females) i had to by the male parts also...useless...i tried to plug it up 2 my dvd player and it didnt do anything....3rd time they sold me an hd15 male to rca (red,blue.green)cord....I got basic cable right now so no box plan on having a box buy this friday...what time warner box should i get? Someone pleaseeeee help im stressing and missin all my tv shows =(
    Info u my need
    General
    Display Type LCD display / TFT active matrix
    Width 20.1 in
    Depth 5.9 in
    Height 16.1 in
    Weight 15.4 lbs
    Enclosure Color Black
    Display
    Diagonal Size 22" - widescreen
    Viewable Size 22"
    Dot Pitch / Pixel Pitch 0.282 mm
    Max Resolution 1680 x 1050 / 60 Hz
    Color Support 24-bit (16.7 million colors)
    Max Sync Rate (V x H) 75 Hz x 83 kHz
    Response Time 5 ms
    Display Positions Adjustments Tilt
    Display Screen Coating Anti-glare, hard coating
    Signal Input DVI-D, VGA
    Features HDCP
    Image Brightness 300 cd/m2
    Image Contrast Ratio 800:1
    Image Max H-View Angle 160
    Image Max V-View Angle 160
    Video Input
    Analog Video Signal RGB
    Digital Video Standard Digital Visual Interface (DVI)
    Expansion / Connectivity
    Interfaces 1 x DVI-D - 24 pin digital DVI 1 x VGA - 15 pin HD D-Sub (HD-15)
    Miscellaneous
    Cables Included 1 x VGA cable
    Flat Panel Mount Interface 100 x 100 mm
    Features Security lock slot (cable lock sold separately), wall mountable
    Certified for Windows Vista Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
    Power
    Form Factor Internal
    Voltage Required AC 120/230 V ( 50/60 Hz )
    Power Consumption Operational 40.6 Watt
    Power Consumption Stand by / Sleep 2 Watt
  2. Heres the back of my lcd monitor
