I have a sound card that has no drivers for Windows 7, only for XP. If I run Win7 in XP mode, will it be recognized? Thanks
Results 1 to 11 of 11
No. The mode is for software compatibility, not hardware..
Find out the chipset for the card. You'd be surprised at what's available. -
Thanks for the replies. I suspected that Win7 XP mode was only for software compatibility, not hardware. What if I use VMWare software to run XP in Win7? Will that support hardware too?
By the way, the sound card is the VOYETRA TURTLE BEACH SANTA CRUZ PCI card. It's discontinued, it came as OEM with my Dell Dimension 8200 PC in 2002. I went to the official website and it claims that the driver does not support Win7. I wonder if there is any 3rd party driver for this card. Here's the link:
http://turtlebeach.com/support/index.php?View=files&CategoryID=311
UPDATE: I found this website, they seem to provide a working driver for Vista/7. Will report back.
http://www.ssstjy.com/wenzhang/wz41-cs4630c.htmLast edited by alegator; 8th Apr 2010 at 12:44.
Unless the card has specific Vista/7 drivers, you will be out of luck. Starting with Vista, the whole WDM audio layer in Windows has been changed. No legacy drivers will work.
John Miller -
If this card is somehow special, you can dual boot to XP.
http://www.kiva.org/about -
I have the Santa Cruz working just fine on a Windows7 PC, but it was a long process! I started with a fresh XP install (SP3), did a Vista Home Premium upgrade, then a Windows7 upgrade keeping all the previous settings and files. This process took about 5 hours, without figuring in the harddrive format. The only activation that was necessary was for Windows7.
That's a very good option. I have tested Win7 in my Dell Dimension 8200 and it runs very smoothly. The only devices that are not compatible with Win7 are:
- The mentioned sound card in this thread.
- The external scanner and printer (both old HP models)
The sound card I rarely use it as I use a Plantronics USB headset which works with Win7. The same goes with the printer/scanner, I only use them occasionally. So maybe the best option would be to create a minimum WinXP installation for the rare occasions when I need to use the external speakers or print/scan documents, that I can access by dual booting from the main Win7 installation.
I've heard before about this option, but I thought it had issues. But it seems to be easy to implement and trouble free. I found this nice reference:
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html
Wow, I never heard of a case like yours. I wonder why that works. In any case I think so far the best option is dual boot.
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 07:17 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 19:02 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 15:26
