What cameras are on the market that support continuous high-frame-rate recording? I was hoping to find something under $2000 that could do 480p on the order of 1000fps, but the only camcorder I have been able to find that support continuous high-speed recording is the Casio Exilim series, and those only do lower resolution as you increase frame rate -- i.e., 512x384 (300 fps), 432x192 (600 fps), and 336x96 (1200 fps).
Results 1 to 12 of 12
Those are quite a bit out of my price range -- looks like they start at around $10k.
I don't think you're going to find anything that does high speed video at 480p for US$2000. 640x480 YV12 video at 1000 fps runs about 600 MB/s. That requires a very fast RAID drive to capture uncompressed. Or a very powerful compression chip for realtime compression.
I know it's a challenge, but the technology has been there for several years now:
- $200 buys a state-of-the-art, mighty powerful image compression processor.
- A 7200rpm SATA or SSD drive without any tricks can handle sustained writes at over 60MB/s.
- For my purposes at least, I'd accept reduced color depth in order to boost peak frame-rates.
It's not a common want-list item.
It's not a question of whether the technology bits are there; it's a question of whether there's enough perceived market demand to make it profitable to spend the $$$ to roll the technology bits together into a product, and then manufacture, market, and distribute it. That's expensive. As LS says, not enough (perceived) demand.
Maybe the Time Warp show on the Discovery channel will increase interest in high speed video.
Not continuously over the full drive capacity. 60MB/s would need a 2 disk RAID zero*. RAID 0 starts one drive at the fast end and the other at the slow end for constant average sustained write rate.
Yes reduced color depth or data compression could allow use of one drive. In most industrial or scientific high speed projects, color accuracy isn't required.
* A WD Raptor may be able to maintain 60MB/s at the slow end of the drive.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Recording High Quality Sound on PC
By evil nemesis in forum EditingReplies: 11Last Post: 25th Feb 2012, 14:36 -
High Speed Component Cables?
By dpunkz in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2011, 22:27 -
hd-dvd to high def mp4/divx/mkv options?
By yoda313 in forum Blu-ray RippingReplies: 31Last Post: 1st Mar 2009, 19:40 -
Please, best options for mencoder? (high quality reencodings and no blocks)
By BlooderButcher in forum Video ConversionReplies: 1Last Post: 21st Nov 2008, 13:53 -
Live stream recording: how to make it continuous
By igorek in forum Video Streaming DownloadingReplies: 1Last Post: 25th Oct 2008, 19:29
