I bough a home cinema that has USB port for media files and DvD drive.
The problem is that I have many DvDs in file format (VIDEO_TS, AUDIO_TS) and I cannot watch on the home Cinema as DvD.
I can open each vob file separately but I cant use subtitles and other DvD interactive functions.
Is the only solution to burn them to DvD disk or could I have an alternative?
What is Home Cinema ? Do you means a DVD player with a USB port, or a PC hooked up to the TV ?
If it is a DVD player with a USB port then you are stuck with whatever it allows. If it can't do DVD structures from USB then you may have to convert the files to something it likes, such as AVI files with SRT subs. No menus, but playable.
You would have to provide more detail about the actual device, and perhaps spend some time reading the manual that came with it to find out what it can play.Read my blog here.
It's a Samsung HT-Z120 Home Theater (5.1). The manual does not mention anything about that case. *.ifo files are not visible on the menu.
Which is better quality capture- DVD recorder or Hauppauge WinTV USB stick?
By akalsha in forum Capturing and VCRReplies: 9Last Post: 6th Mar 2012, 19:57 -
Watch DVD WITH Menus from Hard Drive and USB Stick
By Squirl1899 in forum Newbie / General discussionsReplies: 6Last Post: 4th Oct 2011, 14:25 -
Convert FLV for DVD Player on USB stick
By rob_g9 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 09:10 -
m2ts for PS3 on USB stick or DVD
By leopardx in forum Media Center PC / MediaCentersReplies: 2Last Post: 14th May 2009, 10:56 -
how to watch TV online: by stick? by internal card? by software? HELP!
By sarainelkins in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2008, 14:05
