When trying to burn a DVDwith Magix Photostory CD/DVD 8, I continue to get an encoding error. The following is the last lines of the log for 2 separate attempts:
078: Step 4 of 6, Creating DVD image...Error: 84F
468: MDA reports error 0x84000fb4 - read file from source failed
656: Step 4 done
656: ERROR: PrepareDVDVideoFiles() failed with errNo 5 - encoding failed
781: !!! DBK error in BurnProject: 45 - movie encoding failed !!!
I've tried several changes/adjustments to my transitions, photos, etc, but get the same results. I have 130 photos plus transitions & music. My burner will copy another DVD so I know it is working properly. I have uninstalled & re-installed Photostory but doesn't change the results. I've struggled with this program for weeks! Does anyone have a suggestion about how to correct this?? I've sent requests for help on their forum but they don't respond. Their forum has over 4800 requests....less than 900 have been answered. Some questions are over a year old. How does this program get a #1 rating with zero customer service?? Does anyone have experience with this Magix program? I appreciate your help.
My computer:
Dell DHP , Win XP w/svc pack 3
Pent 4, 2.8 GB 1.5 GB RAM
250 GB Maxton HD, 500 GB Seagate ext. HB
Sony DRX-840U DVD/CD rewritable burner
Online ratings are like testimonials - the only good use for them is to print them out on toilet paper, then use them wipe yourself. Other than that they have little value.
At a wild guess it doesn't like one of your image files, but that is just a guess. However the only way to find out which is to remove them one at a time and try again until you have found the culprit.Read my blog here.
Thanks for your response, guns1inger! Does the error message indicate that its a pic causing the problem & not a transition or the music track? Looking at the error message, it appears to me that the problem showed up during step 4 in the 1st run. But in the 2nd run, step 4 was completed, indicating to me that there is 2 different problems??
Conversion errors in dvd slideshow gui during export burn to disc
By outdoorsyisin in forum Authoring (DVD)Replies: 2Last Post: 16th Mar 2012, 11:29 -
Burn Errors due to MPGV ?
By mrlewp in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2010, 19:54 -
New here- trying to convert files to burn to DVD using AVStoDVD... errors..
By tressls in forum Authoring (DVD)Replies: 6Last Post: 7th May 2010, 16:25 -
How to check for encoding errors
By Dark Alpha in forum Video ConversionReplies: 5Last Post: 30th Jan 2010, 10:25 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22
