Sorry if the answer is already posted on this forum, but I couldn't find any yet.
I just went to Best Buy and saw majority of the mid range laptops now have HDMI port.
And I wonder if it could transfer both Audio & Video to my AV receiver through HDMI.
If yes, is video 1080p? and how many channels do they support?
Thanks in advance
	I would give that a qualified yes. The laptops that have HDMI ports must support HDMI specs so all of the data should transfer to your AV receiver. However, there are plenty of forums that deal with the wonkiness of particular brands not sending audio through the cable. Dells in particular has many models where the audio driver just doesn't work over HDMI. The bigger concern is whether the CPU can handle the video. From what I have seen, nearly all modern computers can handle 720p without issue. Full Blu-Ray rips are another issue, though. My Core 2 Duo at 2.6 GH stutters on VC-1 and AVC Blu-Ray rips. MPEG-2 HD plays fine. If your needs are only DVD, the mid range models at Best Buy should work fine.
	You need to review the specs to know whether audio or any other spec is supported on HDMI. There is no standard that requires audio to be present. As festmaster implies, 1080p is about desktop display and has no relationship to ability to play Blu-Ray or any other file.
 You need to do your homework.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20
  Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 17:33
  Need help with HDMI, DVI-HDMI and "high definition audio device"By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 01:15
  multimedia player connection via hdmi but monitor doesnt have hdmi slotBy ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 10:40
  HDMI Video OR Audio out, Can't Get bothBy the4starish in forum Newbie / General discussionsReplies: 6Last Post: 28th Jun 2008, 14:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
