Dear forum readers,
my DVR-433H is faulty,
when I tried to videoedit on a nearly full not unfregmanted HDD while recording (opps), it froze.
Since I had no other option I unplugged the power cable, then replugged it.
This "solution" (sooooorrry I know this is stuuupid) saved me several times.
Once my recorder had to reinitialize the HDD, it was pain but at least a solution.
But this time I'm in serious trouble:
The player is in endless reboot cycle! powers on, indiciates power failure happened,
tries to fix, then turns off, turn on, indiciates starting after power failure...
tries to fix it, then turn off, turn on, indicates ..... etc.
It can't fix itself.
I would be happy even if it would start with the option to reinitialize the hdd.
please help me !
I would suspect a problem with capacitors in the power supply section. If so, then that would be an easy fix for a competent technician.
Critical Error (Event ID 41 Kernel-Power) causing win7 BSOD & reboots
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 28th Mar 2012, 16:19 -
newbie question pioneer dvr-433h hard drive restore?
By isakiel in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Nov 2011, 06:06 -
pioneer dvr-433h stuck on 'load' and can't operate any buttons!!
By Scubatt in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th May 2010, 03:07 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57 -
Hard Disk Replacement on Pioneer DVR-433H
By linkox in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jun 2008, 19:21
