I have just downloaded a blu-ray film at 26gb because i want to experiment with decoding it to MP4, AVI and MKV before i commit to upgrading to bluray to check on the quality and the time factor in decrypting films to one of the 3 above.
I want to decrypt them at about 4gb first then try 8gb to check on quality and decide which would be the best to go for and also to check out the programs that will be used to decrypt them.
When listening to the film i realised the voice audio was a bit low but the music and effects were quite loud i have adjusted my realtek HD audio manager settings and that makes the voices louder but also the music and effects i have also noticed this on other decrypted blu-ray films that i have downloaded, so im not sure what the problem is, i have the latest K-lite codecs. I was watching on media player classic as that is the only one i have on my pc at the moment
What i would like to know is how best to start in my experiment what would be the best programs to use and is the k-lite codec pack enough or should i be downloading something else and what can i try to make the voices louder without making the whole film louder can it be an audio codec problem or could it be the program i am using to watch it and what is the best program to watch full blu-ray films and decrypted
Any help and advice on this would be appreciated
Closed Thread
Use Ripbo264 to convert blu-ray to mkv or mp4. Play those with mpchc.
And where can I download blu-ray movies? :P
You can try www.torrentz.com or http://hd-torrents.org/ but you will need to find someone with an invite or donate but the films are ratio killers lol if you download the full movie
Blu-Ray Burner Advice Please
By leebo in forum DVD & Blu-ray WritersReplies: 25Last Post: 22nd Sep 2012, 11:49 -
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 14:28 -
Need advice on playing blu ray isos
By dafoe in forum Media Center PC / MediaCentersReplies: 7Last Post: 28th Nov 2010, 22:53 -
Blu-Ray Subtitles (Only when they are needed, not all the time)
By nexus69 in forum Blu-ray RippingReplies: 2Last Post: 23rd Apr 2010, 11:11 -
Blu Ray Region Advice
By Gregbert in forum DVD & Blu-ray PlayersReplies: 10Last Post: 28th May 2009, 09:34
