I am confused with this player because I cannot understand why it plays some .mkv files and others- doesn't.
This file plays perfectly:
Writing application : mkvmerge v2.5.3 ('Boogie') built on Mar 7 2009 15:00:41
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 12mn
Bit rate : 6 907 Kbps
Nominal bit rate : 7 076 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.250
Stream size : 3.52 GiB (80%)
Writing library : x264 core 67 r1173M f6d3166
Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=1 / me_range=12 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=24 / keyint_min=2 / scenecut=40 / rc=2pass / bitrate=7076 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
The problem with this one is that when something moves it leaves a trail of pixel artifacts with odd colors
Writing application : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
Writing library : libebml v0.7.7 + libmatroska v0.8.0
Video
Format : AVC
Format settings, ReFrames : 12 frames
Duration : 2h 8mn
Bit rate : 3 260 Kbps
Nominal bit rate : 3 355 Kbps
Height : 720 pixels
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.148
Stream size : 2.92 GiB (67%)
Writing library : x264 core 84 r1400M 20fa784
Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=8 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3355 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=39000 / vbv_bufsize=32000 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0 / nal_hrd=0
What do I miss? What is with the second file?
Results 1 to 11 of 11
You're not going to want to hear this and I have no solution for your problem, but you need to hear it anyway. I understand why you want to play everything on your BluRay player, but the reality is that when you decide to use a DVD or BluRay player as a "plays everything" device, the reality is that they do NOT play everything. In fact, there is a lot that they won't play. This kind of fussiness where you ask "Why file A won't play but file B will even though there is no real difference between them?" is just how playback is on DVD and BluRay players. If you want a "plays everything" device then you need a dedicated media player like the WD TV or something similar. DVD and BluRay players have limits on what they will play due to either chipset limitations or firmware limitations. We got this question all the time when playing Divx on DVD players was all the rage. Now it's about playing MKV files on BluRay players. Maybe someone will post with some suggestions on what you'll have to do to fix it, but it's probably going to be like the old days with Divx where the "solution" is going to require you doing a lot more work on the MKV files than you probably really want to, maybe even having to re-encode them.
My general concern is to understand what these limitations are. Even if I have to re-encode I have to know how to make it properly
@Atak_Snajpera Can you explain what ref=12 and wpredp=2 refer to (for dummies
Ref=12 could be too high for your player, and wpredb=2 may not be compatible. I suspect it's the latter that's causing the trouble. Encode with wpredb=0 and see if it works. If not, try ref=6 or something reasonable like that.
"camoso" ---> I have same problem with you. I am using BDP-7300 and most of MKV video files are pixalates.
If you could solve this problem, please give me info about that. Did you try making "wpredp" value 0 ???
Please, I will wait your answer. Thanks... -
@oguz_90
sorry for the delay, i haven't checked the thread for a while
as far as i get it the problem is in "wpredp" value. this means weighted prediction for p-frames which are some intermediate frames which help form the actual frames (or something like that, i'm not much into these things). So setting to 0 should fix the problem. I haven't tried it, because i don't have time or powerful enough pc but tell me if you try it. -
@oguz_90 It is good news changing wpredp is enough. What PC do you use? is there any significant change in the quality?
Quality is same with the original one. My PC : Core 2 Duo E 7200 @ 3.8 Ghz , 1066 Mhz Dual Kit Ram , WD 500 Caviar Black ...
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Philips BDP7500 firmware hack
By Sylph in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Dec 2010, 15:05 -
Philips BDP7500 question
By camoso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2010, 10:47 -
.mkv on Philips DVP5960?
By Conrad007 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2009, 12:11 -
MKV to MP4 for Philips TV
By staljin in forum Video ConversionReplies: 2Last Post: 24th Jun 2009, 09:45
