Well I've been using multiAVCHD for a while now (version 3.0) and it had all been working fine. The other day I found out there was a newer version, 4.0, so I downloaded and installed that.
Trouble is, whenever I put files in to be turned into AVCHD format they always error on the advanced subtitle processing. I've checked the settings and they're all the same as they used to be, and yes advanced subtitle processing is enabled.
So now all I get is the video file which runs fine in my PS3, but with no subtitles. I've tried it with many files, even files which I've used in the past and I know for sure that the subtitles worked back then and they now no longer work.
So I decided to revert back to 3.0 as I know that version worked for me and I'm comfortable with it. So I uninstalled 4.0, reinstalled 3.0 but whenever I launch 3.0 it just launches in a blank gray window, with nothing to do in it except click the x button to close it.
I get no errors in installation so I can't think what the problem is.
Tl;dr, advanced subtitles don't work any more but they used to (tried files which previously worked for verification). Also, when launching 3.0 I get blank gray box.
Any help will be much appreciated.
Last resort would be to do a system restore to a date before V4.0 was installed and then install V3.0.
Yeah it's all sorted now thanks to Dean, I posted here as well in hopes of a quick reply ^^
I've have a related issue with subtitles.
I have multiAVCHD v4.1 DAT v771, ffdshow, AVIsynth, HaaliSplitter and Java.
Yet, whenever I try to author a BD with subs it fails at "processing subtitles.." or while running tsmuxer or "missing info.."
This happens only if I try to mux subs. Doesn't matter if it's .srt, .sub or .sup and also if Advanced Subtitle Processing is enabled or disabled.
I've have Windows 7 Ultimate x86/x64 dual boot. Neither works. Yes, easySup works without multiAVCHD on x86.
All the features used to work. Suddenly the subtitle function got messed up. Update?
Reinstalling multiAVCHD, ffdshow, AVIsynth, HaaliSplitter and Java several times hasn't helped at all.
Please help.
(I can't post on Dean's forum as membership is no longer open)
MultiAVCHD and AVCHDCoder both just don't work with x264 64bit - Why?
By borst_one in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Jan 2012, 10:12 -
Once I put an MKV thru multiAVCHD the subtitles are lost
By mahogany in forum SubtitleReplies: 4Last Post: 8th Oct 2011, 14:49 -
multiAVCHD misses multiple audio or subtitles tracks
By Japo in forum Authoring (Blu-ray)Replies: 2Last Post: 24th Jun 2011, 18:26 -
Play on the menu of multiAVCHD does not work......
By NZBPirates in forum Authoring (DVD)Replies: 3Last Post: 10th Sep 2010, 15:51 -
SVCD2DVD used to work, no longer
By gddeluca in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 23rd Sep 2009, 10:45
