Results 1 to 13 of 13
  1. Member barkinglama's Avatar
    Apr 2010
    All up in your internets
    I got this player to play mkvs from my homeserver, so went out and bought a BD Rom drive and a USB enclosure.
    First thing I found is that Leopard doesn't like ROM only drives, second thing I found was that the BD 390 doesn't like mkvs that use the VC-1 Codec.
    So
    I had to rip using MAKEMKV in windows then pass the resulting package through handbrake on the MAC using the h264 codec.
    My first attempt at this, though time consuming, was successful and I ended up with a very good quality < 4GB file (from original 13GB file).
    My second attempt wasn't.
    I followed the same process and ended up with a 9GB file from a 19GB original, but it is pretty much unplayable.
    Lots of pixelation and pauses, out of sync audio etc.
    What could have went wrong?
    I even tried the PC version on handbrake and this took 2 days to produce a similarly broken file.
    Any help appreciated
    Post the details from the mkv that does not work. Use mediainfo.
  3. Member barkinglama's Avatar
    Apr 2010
    thanks for the reply
    here's the info on the original 19GB file
    General
    Complete name : D:\Video\X-Men_Origins_Wolverine\wolverine.mkv
    Format : Matroska
    File size : 19.4 GiB
    Duration : 1h 47mn
    Overall bit rate : 25.9 Mbps
    Encoded date : UTC 2010-03-27 15:02:36
    Writing application : MakeMKV v1.5.2 beta win(x86-release)
    Writing library : libmakemkv v1.5.2 beta (0.7.7/0.8.1) win(x86-release)
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Muxing mode : Container profile=Unknown@4.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 47mn
    Bit rate : 21.8 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.438
    Stream size : 16.3 GiB (84%)
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 1h 47mn
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Resolution : 24 bits
    Stream size : 1.13 GiB (6%)
    Title : 3/2+1
    Language : English
    Audio #2
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 1h 47mn
    Bit rate : 448 Kbps
    Stream size : 344 MiB (2%)
    Title : 3/2+1
    Language : English
    Audio #3
    Format : AC-3
    Codec ID : A_AC3
    Duration : 1h 47mn
    Bit rate : 448 Kbps
    Title : 3/2+1
    Language : Spanish
    Audio #4
    Format : DTS
    Codec ID : A_DTS
    Duration : 1h 47mn
    Bit rate : 755 Kbps
    Stream size : 579 MiB (3%)
    Title : 3/2+1
    Language : French
    Audio #5
    Format : AC-3
    Codec ID : A_AC3
    Duration : 1h 47mn
    Bit rate : 448 Kbps
    Title : 3/2+1
    Language : Portuguese
    Text #1
    Format : PGS
    Codec ID : S_HDMV/PGS
    Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
    Language : English
    Text #2
    Format : PGS
    Language : Spanish
    Text #3
    Format : PGS
    Language : Spanish
    Text #4
    Format : PGS
    Text #5
    Format : PGS
    Text #6
    Format : PGS
    Language : Chinese
    Text #7
    Format : PGS
    Language : Chinese
    Text #8
    Format : PGS
    Language : French
    Text #9
    Format : PGS
    Language : French
    Text #10
    Format : PGS
    Language : English
    Text #11
    Format : PGS
    Language : English
    Text #12
    Format : PGS
    Language : English
    Text #13
    Format : PGS
    Language : English
    Text #14
    Format : PGS
    Language : English
  4. Member barkinglama's Avatar
    Apr 2010
    and from the 6GB converted from the first file in handbrake
    General
    Complete name : \\\movies\wolverine.mkv
    Format : Matroska
    File size : 5.72 GiB
    Duration : 1h 47mn
    Overall bit rate : 7 633 Kbps
    Writing application : HandBrake 0.9.4
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, ReFrames : 2 frames
    Muxing mode : Container profile=Unknown@4.0
    Duration : 1h 47mn
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Writing library : x264 core 79 r1347 5ddd61b
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : A_AAC
    Duration : 1h 47mn
    Channel(s) : 2 channels
    Language : English
  5. Member barkinglama's Avatar
    Apr 2010
    A bit of an update:
    I had tried to play the 19GB and 6GB files via DIVX+ and VLC on the MAC - much pixelation and crashing, I have tried with VLC on vista, I then tried streaming them off my WHS with the bluray player (which I had done sucessfully with another "HD" MKV made in the same way). This was all at the weekend and was very dissapointing.
    After posting I took a general look around the site, I downloaded WMP Classic and tried both files from a USB HDD and they both played fine (well first 15 mins but usually it's crashed by now).
    So
    I stuck the USB HDD into the LG BD390 (it still won't play the 19GB but that's to do with no VC-1 support) but the 6GB played fine - again have only played around 15mins. Encouraging as it seems that the files are OK.
    My setup is Mac Mini wired to a netgear gigabit switch, wired to the latest Airport Extreme, wired to my Windows Home Server Gigabit port running media connect and nero media home essentials, LG wireless N to the Airport Extreme. (all wires cat 6)
    So I tried streaming the 6GB file again through the LG BD390 with the same result pauses, pixelation, audio sync loss - just so happens I have an Airport Express (N) just below the player so and I tried wiring the BD390 to it so that both the inbuilt wireless and the 10/100 ethernet were connected at the same time.
    I restarted the file and it appears to be streaming OK (will test later the full file)
    Out of interest here's the info of the first MKV I made that does stream OK
    General
    Complete name : \Videos\mkvs\the hangover.mkv
    Format : Matroska
    File size : 3.67 GiB
    Duration : 1h 39mn
    Overall bit rate : 5 272 Kbps
    Video
    Format : AVC
    Duration : 1h 39mn
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1h 39mn
    Language : English
  6. Member barkinglama's Avatar
    Apr 2010
    I have found that some makemkv rips can't be read by handbrake - I think this is because of the DTS soundtrack held withing the MKV. I am going to try to use avidemux to convert theses mkvs to a format that the LG likes, anyone have any ideas of the best settings to use?
  7. you want to try uncropMKV I own a bd370 and all mkvs ive used it for play fine after using it
  8. Member barkinglama's Avatar
    Apr 2010
    thanks, what size of files do you end up with?
    what settings do you use?
  9. output size depends on the bitrate setting, higher the bitrate bigger the file and better the quality --wouldnt recomend going below 4500
    size also depends on lenght of film ,using uncropmkv will also let you to pick which audio you want and get rid of others if you dont want them
  10. Originally Posted by barkinglama View Post
    Handbrake passes through DTS just fine, as far as I know. Your problem probably lies elsewehere. Ask on the Handbrake forums.
  11. Member barkinglama's Avatar
    Apr 2010
    I have given up on handbrake at the moment and am experimenting with avidemux just now , tried the handbrake forums without success
  12. If you want to use AVIDemux, make sure you use the preset system (the "slow" preset is probably a good choice). You'd also be well-served by using CRF encoding at a CRF value between 20-22, depending on how big you want the file to be. (20 = larger, 22 = smaller).
    Check the AVIDemux forums for advice on encoding. I haven't used it myself so can't help you there.
  13. Member barkinglama's Avatar
    Apr 2010
    Thanks I'll give that a go
    Just noticed there is a firmware update for the bd390 - updated it and the original mkv now plays though it's stuttering badly
