hi all,
what a great site... very glad i found it. used the vcr buying guide to get an ag-1970 to use to convert tapes to dvd, etc...
i've got it and it did not come w/ remote or user guide, but i'm fairly familiar w/ vcr's, etc...
my question is: when playing tapes, the sharp/soft slider does not appear to have any effect, and when i flip some of the buttons on the drop panel, no lights change in the display or come on, etc... i'm thinking that the panel may not be working, as i would think indicator lights would come on when switching in/out of mono, or such...
could anyone please enlighten... and then i guess my next step is to get a manual...
thanks!
jc
I have not found the AG-1970 operating manual online but you can download the AG-1980 operating manual here
http://service.us.panasonic.com/operman/findmanual.aspx?model=AG
and it is similar enough that you can get a leg up.
If you need a service manual you can buy the AG-1980 service manual (pdf download) for $19 at
https://www.manualsparadise.com/ShowProductsForModel.do?model=M58782728
and it includes the operating manual. The two are close enough that you can mostly get by with the 1980 service manual.
Paul -
found my own answer.... no one else could ?!
the edit switch was on- thus disabling the sharpness slider and TBC switch. -
jcolegrove,
Could you contact me by Email? Got a question for you.
Paul
paul at pgoelz dot com
Is my Panasonic AG-1970 too old?
By pgoelz in forum Capturing and VCRReplies: 15Last Post: 5th May 2011, 11:45 -
Panasonic AG-1970: Displaying Captions?
By MonicaMarlo in forum SubtitleReplies: 3Last Post: 12th Jan 2010, 16:38 -
Panasonic AG-1970
By BryanG in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2008, 17:52 -
Panasonic AG-1970
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 19th Mar 2008, 22:51 -
Old 1970's Song Name??
By scustalow in forum Off topicReplies: 1Last Post: 29th Jun 2007, 11:53
