I was looking at this website that sells region free DVD/BluRay players:
http://www.world-import.com/region_free_blu_ray_DVD_players.htm
Question #1: What I don't understand is why all these expensive players (except the Oppo) are not multisystem (ntsc/pal).
(See screenshot)
I can remember that a few years ago, most $50 DVD players were multisystem (play ntsc or pal disks and output ntsc or pal at the touch of a button).
Question #2: I see this website also sells ntsc/pal converters. How does that work? Do these converters do a perfect job?
Question #3: I see that these players are modified to be region free. Who does these modifications?
Question #4: Do these players put out a Macrovision signal (make analogue VCR/DVD copying difficult)?
1) Because Sony and Hollywood don't want you importing discs from other countries. They want to control what you can watch and when.
2) PAL/NTSC converters vary in their quality.
3) Usually whoever sells them.
4) Yes (if they have analog outputs at all). -
The "early high dollar" DVD players were not multi system either....and many still aren't. It wasn't until you could buy a $39 DVD player is when you were pretty certain you could get into the menu to change the output format.
Bluray remux and Bluray re-encode question
By mocqueanh in forum Blu-ray RippingReplies: 4Last Post: 22nd Feb 2011, 21:25 -
Multi mkv files with subs into one disk to play to all bluray players
By fits79 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Dec 2010, 07:27 -
Minimum System requirements for Bluray ripping/burning?
By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 12:32 -
Any US BluRay players meet these specs?
By amckinney in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Jun 2010, 14:17 -
BluRay / HdDvd combo players
By SCDVD in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Dec 2007, 20:26
