ok, i know this issue is dealt with in the FAQ, however, whenever i change the audio over to a wav file and use tmpeg it still fails and gives me the same darn message..please help...it's driving me insane..i've tried repairing the avi, everything, but nothing seems to work!!
any help would be great!![]()
see i have no problem using avi2vcd (as of yet) but it is taking so long to convert that its probably going to take 18 days!! is there any faster solution??or some way to speed up the process with avi2vcd?
go into TMPG, under OPTIONS, ENVIRONMENTAL SETTINGS, to the VFAPI tab. Right click and raise the priority on your DIRECT SHOW MEDIA FILTER. This should solve it
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Thanks a lot, it worked for me. I have been trying to fix that problem for years. WELL THANKS A LOT!!!! (I'M SERIOUS)
One question, will doing this effect me when I convert AVI files to VCD?
Any current ffmpeg builds floating to the top?
By Calidore in forum Video ConversionReplies: 0Last Post: 11th Jun 2011, 15:22 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 19:41 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
slide show - heart shape & floating hearts
By kj1983 in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2008, 15:16
