can some one recommend a seller on line for brother laser refill .I bought the HL-2140 few months as a gift for my in law .right now the toner is running low and no way I'm/them going to buy a toner for $40 .heck I got the printer for $20 (with a $35 gift card)
I used this trick .it worked but not for too long
http://www.youtube.com/watch?v=hPCGZZIdXyM
Results 1 to 9 of 9
You can't easily refill your own toner carts. Some are impossible.
Your standard OEM carts are better than generic refills, often within just $10-20 of one another.
Here is a refill cart from SMS, available from $30: http://tinyurl.com/ydverzf
Don't compare printer costs to ink/toner costs. That's where they planned to get you all along.
Monoprice has these:
http://www.monoprice.com/products/product.asp?c_id=107&cp_id=10702&cs_id=1070201&p_id=...seq=1&format=2
Looks like they are out of stock for a couple more weeks if you can wait that long. -
You also may want to look at this first
http://www.youtube.com/watch?v=hPCGZZIdXyM -
Another reason why I like Minolta lasers, I can set it to 1% warning level, and still just choose to ignore. Eventually it will print degraded quality, but it never refuses to print!
I'll refill my inkjets, but no way would I do a toner! That crap must blow about like baby powder.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I have a Brother HL1430 at home it just keeps going until it runs out. I tried refill toner carts over the years but found they were a waste of time. Print quality degraded fairly quickly with toner smearing on pages. Now only use the real thing. Inkjets.. well thats a different story.. Always refills when I can..
http://refill-toner.com/brother/208.html, ie for Brother HL 2140
Samsung ML-2010 here ... new cartridge is refilled twice then thrown ... this prevents keeping toner cartridges which have increased work load wear ... which is the cause of smearing and other print quality problems.
resseting hp printer ink after refill
By cyprods in forum Off topicReplies: 1Last Post: 2nd Dec 2011, 21:08 -
Looking for Color Laser Printer reviews
By SCDVD in forum ComputerReplies: 5Last Post: 1st Jun 2009, 23:43 -
color laser printer advice
By lordhutt in forum ComputerReplies: 6Last Post: 11th Apr 2009, 23:06 -
Recommendations for inexpensive laser printer?
By wiseant in forum ComputerReplies: 31Last Post: 16th Apr 2008, 13:20 -
Laser printer warnings?
By Bartron in forum ComputerReplies: 8Last Post: 8th May 2007, 12:07
