I am new to converting my files back to DVD from AVI, but have been playing with it and having poor luck.
I have tried 4 different disk types (media) 1,2,4,8X burn speeds. Better at lower.
Have tried default audio settings as well as Dolby digital. Auto is better.
Any help would be great.
Also tried this on my old P4 2.4ghz 2g ram, 130 g harddrive, and
my HP 2.2ghz dual core 2.0 gram, 150 gig hard drive.
Thanks for any help. Sorry if this in wrong section.
Also tried FAVC on old PC Took like 6-7 hours and was the worst out of sync yet?
Do the DVD's you made play OK the PC - but NOT on the standalone DVD player ?
Play the video_ts folder created from the authoring directly on the PC.
If it's out of sync, don't create the disk from it.
If it is out, go back to DVD Flick and offset the audio to either make it slightly earlier or later,
depending on the problem.
Having sync issues with DVD Flick?
By bahjan in forum Video ConversionReplies: 3Last Post: 31st Jul 2011, 14:50 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
DVD Flick- audio out of sync and subtitles wont show
By gogumakilla in forum Authoring (DVD)Replies: 2Last Post: 4th Nov 2009, 03:09 -
DVD Flick audio sync problem?
By neo*2 in forum Video ConversionReplies: 4Last Post: 6th Sep 2009, 13:51 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21
