    Apr 2010
    Rogaland, Norway.
    What export settings is the best to use in Adobe Premiere CS4? Let's say that file size is irrelevant, I want the best video quality possible. What file format should I use? What encoder? bitrate? bit depth? framerate? What other settings?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    It varies.
    What are the source formats and what project settings?
    http://www.kiva.org/about
    Apr 2010
    Rogaland, Norway.
    The source has a resolution of 720x576, PAL. Capture format is DV.
  4. Member edDV's Avatar
    Mar 2004
    Then the "best video quality possible" export would be native DV format..
    Apr 2010
    Rogaland, Norway.
    Using "Microsoft AVI" without any codec gives a perfect video quality, but a 3 minutes file is 4,28 GB big. I don't know how to export to raw/native DV.
  6. Member edDV's Avatar
    Mar 2004
    I disagree with exceptions.
    If your source is DV format and your project is DV format, any cut editing will preserve first camera generation quality. Premiere Pro will copy source frames to export without any processing. It will still be identical to the camera original. If you process a transition or filter a clip, Premiere will transcode to RGB and back to DV. Still the second generation DV is low loss.
    Export to uncompressed is also low loss but more loss than export to native DV format. Also uncompressed expands the file size ~5x.
    No export will get you to "perfect video quality". You can only have equal or lower video quality.
