Hi say i want to edit a 5 min clip but want to have diferent settings for some scenes, for example the 1st 1 min of the clip has too much color and after 2nd min the scene is too dark, so can i edit the 1st scene and reduce the color and work on the 2nd scene and brighten the video without cutting and rejoining files or without working with images?
is there anysoftware like that, i cant remember but i think pinacle video editor was able to do that please need some advice or solution thanks.
i know how to do this in avisynth like this example from another thread A=Trim(0,1000).Tweak(Sat=0)
B=Trim(1001,2000)
C=Trim(2001,3000).Sharpen(0.7)
D=Trim(3001,0).Tweak(Cont=1.5)
but can i do this in vegas or after effects? all i want to do is do some color correction in diferent scenes and save as 1 file again.
i tried to split files in vegas but when i select individual split scenes and add filter it does the same for whole video? any ideas? thanks. -
VirtualDub's "Blend" feature allows you do apply filters to ranges of the video.
That's what the blend option does. The author should have picked a better term.
Very easy in Vegas. You have a couple of different ways of doing.
If you are editing several clips together, you can either add Video Event FX to each clip if they all need something different, or put clips that have the same problem on the same track, and the FX to the track. Or a combination - i.e. contrast correction on a per clip basis, then a colour correction to the entire track.
If you have a single clip and you want to adjust only parts of it, you can either split the clip ('S' key), then work as above, or you can apply the effect to the entire clip, and use keyframes to lit it to only parts of the clip.Read my blog here.
How to Edit a video to add slides/pictures
By m.azza in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2011, 10:37 -
How to edit video to add slides into it
By m.azza in forum EditingReplies: 0Last Post: 15th Sep 2011, 10:11 -
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
a software tool that can add mov files,edit, make new file not re-render?
By markm75 in forum EditingReplies: 2Last Post: 24th Jul 2008, 11:53 -
How to edit part of video and add image over it
By method in forum EditingReplies: 2Last Post: 28th Oct 2007, 07:26
