    Apr 2010
    Cyprus
    Hello guys,
    Here is a new service that will automatically rename the found subtitles to match with movie's file, www.fsubs.com, give it a try you just need to enter the movie's filename!!
    -notme1
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Not exactly what you say it is.....
    Looks like a subtitle search engine....
    Apr 2010
    Cyprus
    Noahtuck, if you try to search for a specific filename it renames the found subtitle to match that file. Also you can search for more than one subtitle at a single time (separate them in different lines). You just need to enter complete filenames instead of just show names
