I have JVC MiniDV camcorder model GR-D75OU.
On record and playback the right side of the screen gets large pixelation, and the audio breaks up.
I've checked older tapes that I know are fine, and the same problem is there on playback.
This camera is old but hasn't done hardly any work.
I have two tapes left to transfer to DVD. Is this a fixable problem or should I just bin the camcorder?
Results 1 to 9 of 9
try a head cleaning tape before throwing out the cam.
http://www.bhphotovideo.com/c/product/109332-REG/Panasonic_AY_DVMCLA_AY_DVMCLA_Mini_DV....html#features
or similar from sony, jvc, etc.--
You didn't say whether or not you tried to clean the tape heads on the camcorder. Dirty heads would be the first thing I'd think of.
EDIT: This is the umpteenth time that I've written a reply at the same time as aedipuss. Weird... -
Why do most consumer DV SD capture problems over IEEE-1394 mention "JVC"?
I had similar issues with my brother's JVC cam.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
another test. use a brand new tape and record a short video. play it back. is the problem there?
if the problem is still there it's most likely a dying cam.--
HD Mini DV camera suggestion?
By alange5 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jul 2011, 12:51 -
I need a mini CCD pinhole camera.
By Dittoz in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2009, 20:20 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Capturing widescreen video from Mini DV camera
By eisfeld in forum Capturing and VCRReplies: 7Last Post: 23rd Jul 2008, 19:46 -
Computer won't recognize my Mini-DV Camera
By mschwennes in forum Capturing and VCRReplies: 15Last Post: 14th Dec 2007, 14:50
