    Apr 2010
    Liverpool, UK
    I am a novice when it comes to converting video files, so please bear with me.
    I have a TV series as AVI format, taking up 8.7GB...but I can't get 8.7GB onto a single dual layer disc, and I don't want to have to waste more for a mere 200MB.
    These want to go from AVI to H.264 in preferably the MP4 container.
    HandBrake is what I have installed, though I don't really know how to use it correctly.
    I want to keep as much quality in the video and audio as possible, but making the files as small as possible.
    How do I go about this?
  2. Consider trimming the opening and/or closing credits off a few episode instead -- they're probably all exactly the same anyway. That will save you time and retain the quality since you won't have to reencode anything. You can do this by opening a file in VirtualDub, selecting Video -> Direct Stream Copy, cutting out the sections you don't want (mark-in, mark-out, cut), then File -> Save as AVI.
  3. Member usta's Avatar
    Jun 2009
    Netherlands
    I agree. Alternatively, you can use Avidemux to do the trimming (I like it more than VirtualDub).
