Hello. I took some videos with my mobile phone (LG KU990i) and it was saved in avi format.
When I transfer that avi files to my pc there is audio and video only in VLC player.
The video is playable in Media Classic but there is not audio.
The problem is when I convert it in flv or mp4 format in order to upload them in youtube they lose their sound and in VLC player.
When I try to upload it in avi format there is no audio.
What should I do to solve that problem?
Here is the URL of a video http://www.youtube.com/watch?v=vNpnzQ5db8A
Please give information, what converter(s) are you using? Give more information about your source avi, video and audio codec(identify with mediainfo).
I would try reconvert with xmedia recode, winff or handbrake. All free.
edit: Missed that you already tried upload it as an avi. -
Yea, I will do it.
I used xmedia recode, total video converter, allok video joiner, xilisoft, ultra video converter, aimersoft total media etc but no sound in all the converters.
General
Complete name : C:\V040410_13.240001.AVI
Format : AVI
File size : 9.42 MiB
Duration : 36s 678ms
Overall bit rate : 2 155 Kbps
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 36s 667ms
Bit rate : 2 078 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Resolution : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.225
Stream size : 9.08 MiB (96%)
Writing library : DivX 1537
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Stream size : 287 KiB (3%)
Alignment : Split accross interleaves
Interleave, duration : 33 ms (1.00 video frame)
Interleave, preload duration : 33 ms -
I have tried it but when I played it with VLC or Media Player Classic I only can hear the audio.
I installed K-Lite codecs and now the AVI video has sound and in media player classic.
But as I understood the issue is when I upload to youtube or convert it into flv and mp4 it lose the sound.
I would be grateful if someone tell me a solution. -
You have a mono audio, which probably messes the conversion (notice 1 channel).
So, the issue becomes how to map 1 channel mp3 to 2 channel aac.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
AVI files - audio but no video
By Dream943 in forum Newbie / General discussionsReplies: 0Last Post: 13th Mar 2008, 16:02 -
2 audio AVI files
By warlock110 in forum Video ConversionReplies: 3Last Post: 7th Jul 2007, 21:18 -
Finally my first AVI convertion to VOB ...
By geek2330 in forum Newbie / General discussionsReplies: 11Last Post: 23rd Jun 2007, 09:42 -
AVI files with 2 audio channels
By danjull in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 05:57
