Is there a way to change the aspect ratio of a video (codec is XviD but it says DX50 in VLC - not sure what that means) without losing ANY picture quality?
I know the method of using MPEG4Modifier, but that is not the permanent solution that I am looking for.
Thanks in advance
-m93
				Results 1 to 10 of 10
	It is the only method that doesn't require reconverting(losing quality).
	Are you certain that there's no other way? My media player still reads it as a 4:3 video instead of 16:9.
	What containers does your player support? Maybe you could make an mp4 or mkv with 16:9 from the avi xvid without reconverting the video, using yamb(mp4) and mkvtoolnix(mkv).
	Three questions!
 - What type of player do you have?
- Can you give a step by step description of how you set up and use MPEG4Modifier?
- When you save the new file out of MPEG4Modifier does Mediainfo confirm the change?
	Not all players, AVI splitters, Xvid decoders, and renderers support PAR/DAR flags. If they don't work with your player you'll have to resize and reencode with square pixels.
	@jagabo: Which program would do this best and what settings should I use to keep the video quality the same?
 @netmask56:
 1. Creative Zen Vision W (but its irrelevant because I still want my video file to truly be 16:9)
 2. The original video is 4:3 (640x480). I have used all of the 16:9 options available
 3. No
	If you're asking how you can resize and reencode without losing quality -- you can't. But to do it I would use VirtualDub and the Xvid codec. Set Xvid to single pass target quantizer mode with a quantizer of 2 to 3.
 It's not irrelevant because resizing and reencoding will cause a loss of quality. You could upscale your 640x480 source to ~848x480 -- but you'll probably find your player can't play videos over 720 pixels wide. You could scale to ~704x400 but that will lose ~17 percent of the vertical resolution. Or you could scale to ~640x360 and lose 25 percent of the vertical resoltuion. In all cases you'll lose quality from a second round of Xvid compression.
 If MediaInfo doesn't show a change in the DAR you did something wrong, the file wasn't updated with the new flags. GSpot is better at showing PAR/DAR of AVI files.Last edited by jagabo; 5th Apr 2010 at 09:47.
  WMV Aspect Ratio Changing?By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 07:53
  Changing aspect ratio for WMV?By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 10:27
  Changing a DVD's Aspect RatioBy soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 19:18
  Changing aspect ratio.By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 13:19
  Changing aspect ratio?By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 06:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
