    Jan 2010
    Canada
    Everytime I extract a file over 4gb it says that their is insufficient space on the disk, but that is not the case because I will have at least 15b left on both my hard drives and the same thing comes up no matter what program I use to extract with. Any suggestions.
    USA
    I would probably just get more HDD space. It may be that the programs don't want to cut you too short on free space.
    Sep 2007
    How is the HD formatted. If I remember correctly the disk must be partitioned NTFS to have files larger than 4G. If Fat32 there is an upper limit again 4G if I remember correctly.
    rcubed
    Jan 2010
    Canada
    It's FAT32 but how do you change that to NTFS
  5. Member wulf109's Avatar
    Jul 2002
    Google fat32 to NTFS
  6. Member darkknight145's Avatar
    Feb 2007
    Australia
    windows has an inbuilt converter to convert to NTFS from Fat32, just check out windows help
