Not sure if this has ever been addressed but does the type of video file one plays on a laptop affect how much power and therefore battery life is used up?I'm going on a long flight and want to make my netbook last as long as possible. Thanks.
Depends if your playback format is supported in the display chip hardware (low power consumption) or requires CPU to decode.
DVD MPeg2 is generally supported in most laptop display chips and most laptops are power optimized for playing DVD. If you play from a file rather than from the drive, you save the power used to spin the drive.
AVIVO-HD and PureVideo-HD display chipsets will decode Blu-Ray format high def MPeg2, h.264 and VC-1 in hardware. Other display chipsets may have hardware assist (when properly configured) but the CPU must carry most of the load. High CPU activity burns the most power.
Play your videos and watch CPU activity in the task manager. The lower the better for power consumption. Next issue would be screen brightness. Headphones use less power than speakers.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Generally the higher the resolution the more the CPU and GPU have to work, I would also turn off the Wi-Fi or wireless card when not in use.
http://labnol.blogspot.com/2006/03/10-tips-to-make-your-laptop-battery.html
Camcorder File Formats
By Russo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Aug 2010, 14:20 -
preserve battery life: play video from hdd or flash drive?
By akrako1 in forum Software PlayingReplies: 1Last Post: 7th Jan 2010, 21:55 -
Good Battery Life
By Arlo in forum Portable VideoReplies: 2Last Post: 22nd Apr 2009, 14:52 -
File Formats
By Dan K in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2008, 12:22 -
won't encode full file, and will only do certain file formats
By GregDz in forum ffmpegX general discussionReplies: 0Last Post: 21st Jun 2008, 22:27
