Hi! I'm having trouble burning files and folders to DVDs. I'm currently using Nero 7.8.5.0 and I get an Internal target error, then Could not perform end of Disc-at-once and then finally Burn process failed at 4x/8x. I tried both at 4x and at 8x.
I saved the log for it:
Lazarus
TOSHIBA
1C80-0014-19E5-MA2X-4000-K432-****
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
Recorder: <HL-DT-ST DVDRAM GSA-U20N>Version: HT05 - HA 1 TA 0 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVDRAM GSA-U20N >Version: HT05 - HA 1 TA 0 - 7.8.5.0
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK3252GSX iaStor Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-U20N iaStor Port 0 ID 1 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-U20N F: CDRom0
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1634MB (1673508kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.4.2010
ISO compilation
13:54:28 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
13:54:28 #2 Text 0 File Isodoc.cpp, Line 6608
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
13:54:28 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
13:54:28 #4 Text 0 File Burncd.cpp, Line 3499
Turn on Disc-At-Once, using DVD media
13:54:28 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2188015 (486:13.40, 4273MB)
13:54:28 #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO
13:54:28 #7 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: HL-DT-ST DVDRAM GSA-U20N, Media type: DVD+R
Disc Manufacturer ID: RITEK, Media Type ID: F16, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 7
13:54:28 #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
13:54:28 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2188016 (2188016) = #2188016/486:13.41
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2188016 blocks [F: HL-DT-ST DVDRAM GSA-U20N]
13:54:37 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [F: HL-DT-ST DVDRAM GSA-U20N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4481056768, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2188016 | 0 | 0x00
2188016 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
13:54:37 #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
13:54:37 #12 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
13:54:37 #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
13:54:37 #14 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
13:54:37 #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
13:54:37 #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 4x (5,540 KB/s)
13:54:37 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
13:54:37 #18 Text 0 File Cdrdrv.cpp, Line 9859
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: RITEK...
Media type ID: F16
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 52 49 54 45 4B - 00 00 00 46 31 36 01 38 ...RITEK...F16.8
23 54 37 12 02 50 6E 02 - 8C 68 16 16 0B 0B 0A 0A #T7..Pn..h......
01 1D 1E 0C 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
13:54:37 #19 Text 0 File DVDPlusRW.cpp, Line 674
Start write address at LBA 0
DVD high compatibility mode: Yes
13:54:37 #20 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
13:55:17 #21 SPTI -1061 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0x90
CDB Data: 0x2A 00 00 00 02 A0 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 0E 44 90
Buffer x191f0580: Len x10000
0x25 35 17 06 1E AC 2F 42 F2 59 CD 60 70 A7 11 13
0x5F 9F 2C 28 C7 90 7F D4 F2 D7 39 53 F9 2A A8 6F
0x1C D1 42 66 F7 CE 33 22 CD BA 6D 7E D4 CB 74 D1
13:55:17 #22 CDR -1061 File Writer.cpp, Line 303
Internal target failure
13:55:17 #23 SPTI -1061 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x44
Sense Qual: 0x90
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 04 00 00 00 00 0A 00 00 00 0E 44 90
13:55:17 #24 Phase 127 File dlgbrnst.cpp, Line 1762
Generating DVD high compatibility borders
13:55:25 #25 Text 0 File DVDPlusRW.cpp, Line 934
EndDAO: Last written address 672
13:55:25 #26 CDR -1061 File WriterStatus.cpp, Line 162
13:55:25 #27 TRANSFER -24 File WriterStatus.cpp, Line 162
13:55:25 #28 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 4x (5,540 KB/s)
13:55:25 #29 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
13:55:36 #30 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
13:55:36 #31 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Results 1 to 10 of 10
Just because a disc say's "maxell" on it, that does not mean maxell actually made the disc.13:54:28 #7 Text 0 File DlgWaitCD.cpp, Line 2949
Disc Application Code: 0, Extended Information Indicators: 7 -
Looks like DMA is off. 'Control Panel>Device Manager>IDE ATA/ATAPI Controllers' Try to change it back there. If not, uninstall the channel the device is on, reboot. This will cause no data loss.CdRomPeripheral : HL-DT-ST DVDRAM GSA-U20N iaStor Port 0 ID 1 DMA: Off
And welcome to our forums.
Okay, thanks. Maybe I'll try one of my verbatim discs. The thing is, I didn't use to have any problems burning to this type of disc with the same program. I just don't get why it starts having problems now.
Sorry, but what do you mean but uninstalling the channel the device is on? And thanks for the welcome ^^ hope I can learn more and help others too -
Find the controller channel that shows as DMA off, R click it, select 'Uninstall', reboot. With DMA off, you will have slow disk reads/writes, errors, high CPU usage. It happens when trying to read a damaged disk.
Pioneer DVR-110D - Internal target failure
By tjax in forum DVD & Blu-ray RecordersReplies: 5Last Post: 27th Mar 2011, 17:41 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
Write Error with Internal DVD Writer
By Soviani in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Oct 2009, 00:50 -
Internal Target Failure on Nero
By ChonasMan in forum Authoring (VCD/SVCD)Replies: 12Last Post: 10th Aug 2008, 19:45 -
DVD burning error! =(
By ll ReNeGaDe ll in forum Video ConversionReplies: 44Last Post: 21st Oct 2007, 18:33
