I have a video that i want to know if there is any way i can clean it up..Below is the images of what i get throughout the video at times...Its an avi file is there a tool and guide i can use to convert this into something i can view better?
Avi Details
Codec : DivX 5
Codec/Family : MPEG-4V
Codec profile : Simple Profile/Level 1
Codec settings, Packet bitst : No
Codec settings, BVOP : No
Codec settings, QPel : No
Codec settings, GMC : 0
Codec settings, Matrix : Default
Width : 708 pixels
Height : 356 pixels
Display Aspect ratio : 16/9
Frame rate : 25.000 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Writing library : Lavc51.40.4
Thanks i am very much a begginer so thanks for any help
	Honestly ? Throw it out. If the rest of the video is that bad, you are just wasting your time.
 The top image shows compression artefacts from having too low a bitrate, as well as what appears to be the results of poor resizing of interlaced source. The second shows frame blending and again, poor resizing. There is little you can do to undo the damage of such a poor conversion, and even if you could resolve some of the issues, what you would have left would not be any better, just differently damaged.
 I am happy to be proven wrong if someone like Manono wants to weight in with a super script.Read my blog here.
	Oh..ok thank you  ..its what i was thinking..just wondered if i could save it somehow... ..its what i was thinking..just wondered if i could save it somehow...
  please list the virtualdub filters to remove vhs tape video noiseBy perfection in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2020, 13:45
  cleaning excessive noise with VirtualDub and Neat VideoBy defiantclass1 in forum RestorationReplies: 11Last Post: 16th Aug 2011, 10:24
  How to remove noise from my HD videoBy ITW in forum RestorationReplies: 18Last Post: 26th Jan 2011, 13:24
  how to remove heavy noise in video?By Driftking978 in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2008, 05:24
  Remove noise garbage from bottom of video.By mlong30 in forum EditingReplies: 24Last Post: 10th May 2007, 22:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
