I want to shrink a DVD using DVD Rebuilder. I've read that it always creates a DVD that is 4.32GB. Then I want to take the output and use a DVD authoring program to add menus and chapters. Will there be enough room left on the disc for all that stuff? Could I also run into problems if there is some data too close to the edge?
	Whether or not there's enough room depends on the size of the menu's you make. Ordinarily you'd have 40-50 MB left over, plenty of room to make decent motion menus with audio, at least for the main menu. If you're making static menus, you'll never be able to fill the DVDR. I usually only need 15-20 MB to make a 30-40 second motion main menu, with static menus for the scenes menus.
	Thanks for the info. I will have to look at TargetSectors (or HCTargetSectors), and it's good to know 20MB is probably on the high end of what menus will require. I noticed jdobbs said there might be problems if you write all the way to the edge, so I'll have to keep that in mind.
 And I may need to do the authoring after running DVD-RB. I don't know about all DVD authoring software, but I just found out TMPGEnc Authoring Works does not let you author if you have more than a DL DVD worth of stuff.
  help me how to make a set of avi files to DVD with menus of each avi fileBy mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07
  what program should i use to make some menus with diff chapters?By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2010, 00:48
  How do you make menus for dvds....By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 13:33
  How will I make an AVCD with menus?By zeldAIS in forum Newbie / General discussionsReplies: 19Last Post: 4th Aug 2007, 16:12
  Looking for a presentations program to make dvd menusBy faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 11:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
