  1. Jujumedia Heyjoojoo's Avatar
    May 2005
    Sacramento Valley, California
    For instance, if I am splitting a particular MPEG4 video file into 3 parts for YouTube, I will end up with two parts that give me an error and the last part is perfect.
    The error message I get is from Windows saying something like there's a problem with the audio or error C00D1199 or a corrupt file. This seems to occur about 40% of the time. But usually the last file in the ones that were created by the splitting is perfectly fine. ???
    I've used tons of Splitters and i'll post them here soon.
    EDIT: Splitters I've used:
    TS Splitter
    Boilsoft Video Splitter
    Please post more info about your source, if you don't know use mediainfo.
    But I would try videoredo (latest beta/preview).
  3. Jujumedia Heyjoojoo's Avatar
    May 2005
    Thanks for your response.
    I have been using Leawo DVD Ripper to rip DVDs. These DVDs are from my converting of all my VHS tapes onto DVD which took nearly a year. The Leawo DVD Ripper seems to do a good job thus far. I have used Magic DVD Ripper, Aiseesoft DVD Ripper, Aon Ultra DVD Ripper and a few others. Leawo has many options to rip to and since all videos will go up on Youtube, here's what I use: MPEG4 (XVID) 1280x720, Audio AAC.
    Here's what Media Info indicates with this latest file:
    Video
    Format : MPEG-4 Visual
    Format profile : Simple@L3
    Format settings, BVOP : No
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : 20
    Duration : 12mn 11s
    Bit rate mode : Variable
    Bit rate : 5 501 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.199
    Stream size : 480 MiB (97%)
    Writing library : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 12mn 11s
    Bit rate : 166 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 14.5 MiB (3%)
    Canon VIXIA HG21 || Vegas Pro 9 || Digital Juice || Photoshop CS4 || 2.33 GHz Intel Core2 Quad Q8200 || Windows 7 Pro || 4 Gb Kingston RAM
  4. Jujumedia Heyjoojoo's Avatar
    May 2005
    VideoRedo doesnt read mp4 files. I can't get it to open the file I referenced above.
