Please can you help? I have an MV5i purchased 2003, with some not extensive use it has started developing some intermittent problems. The first time I noticed it, there was something wrong with the quality of the playback (mosaic). I cleaned the heads a few times and all seemed to work fine again. Unfortunately, the problem appeared again, this time also the recording was mosaic. Tried again with the cleaner. Worked fine for a few minutes, but now it does not record properly OR play back, it is always mosaic. Any help appreciated
Regards
Hartless
using old tape? maybe buy a couple new ones and try them after another head cleaning. i recommend only buying one brand/model of tape and sticking with it, as there are problems that can occur when different tape lube gets mixed on the heads.
Thanks for that, but have bought new cleaning tape, still had un-opened new recording tape from a while back. Tried new cleaner followed by new recording tape - result still the same. Started getting "REMOVE CASSETTE" message, looked up in instruction book implies moisture getting in. Looked on net about this and found there seems to be a problem with manufacture of "CCD" chip from sony which alot of cameras from different providers employ and the same problem with them. I have contacted Cannon direct and wait for reply. This may effect other people too, if anyone else has had same problem OR knows of anything else that could cause this please add to this thread
Have had camera back from FREE repairs because Canon had a call back since 2004 for this particular fault, this call back will now end April 2010. Camera works great
Cannon HD cameras
By Tom in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2012, 15:59 -
Cannon HG20
By r67_vette in forum Video ConversionReplies: 1Last Post: 21st Feb 2011, 20:38 -
Cannon Mv5i and apple pro
By cashley in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2010, 14:01 -
Using a Cannon HF10 to record from the PC via hdmi?
By APFable in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Aug 2009, 02:51 -
Can't Capture from Cannon XHA1
By thatbenguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd Oct 2007, 20:53
