Hi,
Is there any way to convert SSA to SUB? I've found a similair topic but with no answer.
SUB files are (from what I've learned) images. So there must be a way to convert SSA to SUB.
when I say convert I also mean the lay-out, position size etc.
The only thing I actually want, is to burn a DVD with date code wich you can turn off/on.
thanks,
Abas
Results 1 to 12 of 12
The flag once raised will never fall!
There is a plain-text format .sub. What you want is probably the VobSub .sub/.idx combo, right?
Unfortunately, I don't know how this might be done, myself - I've been wondering if there was an easy way to convert .ass subs (basically an extension of .ssa) into VobSub format. Subtitle Workshop and other programs I've tried don't seem to allow it, at least not directly.
If cameras add ten pounds, why would people want to eat them? -
Subtitle Workshop did convert the SSA to SUB, but without the style, position etc.
I have a season of Miami Vice with SUB files, that have different styles different positions every now and then.
You would think SUB will handle it, but no. SUB format is not for consumers I think.The flag once raised will never fall! -
Sure, it is. You just have to have the right programs.
Which .sub format did you convert to? As I mentioned, there is a plain-text .sub - which, of course, doesn't support formatting, I believe, so converting .ssa/.ass to that format would likely strip all the formatting, as you experienced. I don't think Subtitle Workshop allows for converting .ssa/.ass to VobSub format.
It'd be nice if there was indeed a way to render .ssa/.ass into a VobSub set, but I don't know if even that would support all the effects.
Sorry I was wrong I want to convert .ASS to SUB. Yeah I converted to DVDsubtitle, that didn't work.
Now I downloaded MaestroSBT. That program can convert SSA to BMP. But I have ASS...
But if I do get it converted to BMP then I can convert it to VobSub, that's what I've read.
I give up. People complain that there is no datecode on the DVD. I dont want to hardcode...but now I have to,
Yeah, it's a little thing I want, but wouldn't it be nice?The flag once raised will never fall! -
If you're just burning a datecode, why do you need style/position?
.SUB is a basic subtitle format for DVD-Video, .SSA and .ASS are modern ones that were never intended for use with DVDs. -
It's only position. On all video's the datecode is shown in the left corner, under. That's what I also want for my video's.
You can do quite a lot using MaestroSBT. I use it most every day. I save in SST format because Muxman accepts those as well as SUP format subs. But you can also save in SON format, and then use Son2VSub to get VobSubs directly. But no Ass subs as input, and you'll have to do a lot of editing, probably, within MaestroSBT, to get the output you want. Here's Son2VSub, in case you want it:
Everybody thanks for the replies.
Thanks manono I will look for it and give later this day answer.The flag once raised will never fall! -
I've converted to SON format, maestro also created TIFF files. Then I used Son2VSub, it created a idx file and txt file.
There is also a sub file, but that's empty (0 bytes). Here I'm stuck.
I think the program can't handle it. But it's also getting a little complicated, I think I can better stick to hardcode.
Thanks everyone for the helpThe flag once raised will never fall! -
If I've used that program once to make SON files for later conversion to VobSubs, I've used it a hundred times. But I haven't used it in several years to make SON files because now I make SST files for Muxman. Anyway, don't use the default TIFF. Try it with Windows 4-bit BMP. Here's a guide:
https://forum.videohelp.com/threads/261209-Subtitles-in-DVDLab?p=1569039&viewfull=1#post1569039
In the guide I mention 8-bit BMPs but, although I think both are OK for SON creation, I'd use 4-bit BMPs these days. -
Thank you manono!
I've followed exactly what you said and now it works.
Next time I burn DVD's I will use this way!The flag once raised will never fall!
SSA/ASS capabilities
By tekkyyy in forum SubtitleReplies: 2Last Post: 12th May 2009, 06:31 -
.OGM and .SSA Combination
By Chaosfission in forum EditingReplies: 5Last Post: 7th Feb 2009, 04:33 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 21:42 -
ass and ssa to sub/idx
By MasterRoshi in forum SubtitleReplies: 10Last Post: 20th Jan 2008, 17:31 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 15th May 2007, 00:33
